5 members (Wayne67vert, Otto Skorzeny, dt235sd, Cosmo, Hanks custodian), 85 guests, and 2 robots.
Topics128,059
Posts1,055,825
#1430644 11/19/2021 12:56 AM
Hi, I've got a couple of Carter carbs. They both need cluth cables. Can ya'll show me how to hook up each of the cables.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
And Remind me how to spell Clutch. And it's a Chock cable.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Originally Posted by SavannahDog
And Remind me how to spell Cluth
You just missed the second 'c'. But we knew what you're talking about. It's Clutch. wink
[on edit] Since you're talking about carburetors, did you mean Choke? If so, you were way off. grin
Yes Your right Its a Choke Cable.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Here's a pic of my Carter YF carb. The choke cable sheath clamps in at the yellow arrow and the wire at the red arrow. You'll need to adjust it so when the choke control is pushed all the way to the dash, the choke plate is vertical in the throat of the carb.
Well mine has a Threaded spot. Where the cable attaches. It's a YF for a Nash 1960 it has a number 877SA.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Well, I guess it got a automatic choke. I don't understand why it has a connection to a threaded connection, unless it used to set it up at first.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
AD Addict & Tinkerer
First off, is the carb for your ‘52 3600? What engine do you have?
The threaded connection is for a heat riser tube that comes from the exhaust manifold. There is a little casing that is attached to the exhaust manifold has a small tube that connects to the threaded portion on the carburetor. The heat from the exhaust (from around the manifold, not exhaust gases), as the engine heats, up causes the spring inside the black casing on the carb, to heat up and expand opening the choke plate. Take some pictures of what you have and hopefully we can tell you what you are missing.
Phil
Project Journals
Stovebolt Gallery Forum
