4 members (GradyB, J Lucas, pauld, klhansen), 206 guests, and 4 robots.
Topics128,204
Posts1,057,289
Members48,467
The oil pump priming tool I borrowed from the local auto parts store is less than ideal. I have a few old distributors sitting around. Does anyone have any instructions on how to make an oil pump priming tool from an old distributor? I realize you would have to remove the gear at the bottom of the shaft. I have not put a lot of thought into it, but it seems like a logical choice if I wanted to make one of my own.
I get frustrated watching YouTube videos. There are so many that are poorly done.
Just have to knock the gear off the shaft and clamp the top in a drill. Works really well.
By far the best priming tool is an old distributor housing, especially on a V8 engine. The screwdriver method and some of the aftermarket priming tools don't allow oil pressure to reach the passenger side lifter oil gallery because the distributor housing seals part of it. Instead of removing the drive gear, I simply grind or machine the teeth off of it. I've also used a bare housing with a piece of round steel stock with a drive tang milled or ground into the end.
My distributor is close to the firewall and I had to build this to spin the oil pump. I could not fit the hand drill directly over the distributor hole. As mentioned, use an old distributor and cut the top off, then add the U-joint so I could attach the hand drill. I pressed a bushing onto the shaft at both the top and bottom to keep things in place.
Mark
Priming tool with U-joint
Bushing on bottom end
I like Mark's idea. Another option would be to put a square socket on the top end of the distributor shaft and use one of the flex extensions. I got one for 1/4 square drive which would work well for this application.
They're currently $10.99 on Ebay, free shipping. Building one is like washing and ironing your used tinfoil for reuse.
1951 Chevy Panel Truck
Thats good to know. I built mine before ebay. Probably washed my tinfoil back then also.
Mark
J Online: Content
A well built V8 will work a 1/2" - high torque drill pretty hard, I am not sure the 1/4" drive flexible extension will hold up for that.
I made one using the collective wisdom gathered here.
Have not used it yet. Several pics. Too many for one post.
More pics.
I use 1/4" drive universal joints to power chamber reamers when fitting rifle barrels on the lathe. Haven't broken one yet. That Ebay priming tool won't pressurize the passenger's side lifter gallery, as I mentioned before.
More and more.
Yes, I have another 283ci to assemble and prime.
Take the modified gear off and that same tool will work to prime a 216/235/261.
Should I grind a hex design in the tip so the drill chuck won’t slip?
Crusty Old Sarge
Crusty Old Sarge
If you scribe a or grind a mark on the top of the shaft that show the position of the oil pump drive it will make it easier to index you distributor. I cheated and bought one from Summit ($10.00), I still marked the top of the shaft though.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Be sure the flats you grind are equal width and centered. A drill chuck has three jaws, so you only need three flats, not six.
The groove down near the gear is actually the one that intersects the oil gallery. On the 265 engines from the mid-1950's, there was a flat spot on the housing instead of a groove. If the distributor was clocked wrong when the engine was assembled, oil would be cut off to the passenger's side hydraulic lifters and the engine would make a terrible racket. 283's got the full circle groove to prevent that from happening.
That makes me feel better. This is the priming tool I used and that lower piece toward top left of the picture would accomplish what you said.
