4 members (TUTS 59, PAUL Berardi, wilbur53, 1 invisible), 112 guests, and 0 robots.
Topics128,132
Posts1,056,376
Members48,441
#1427851 10/25/2021 12:50 AM
Just curious if anyone has used or had experience using a laser cleaner for surface rust? Looks great on the videos but you know how that goes.Real or Joke?
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
I've been eyeing those as well, but am skeptical, since it's promoted on the internet.
I'm wondering if those videos are speeded up to make it look faster than it really is. ohwell
Insomniac
Insomniac
$40 to $50 grand! Doesn't make sense economically for most of us...
https://www.amazon.com/DIHORSE-Hand-Held-Cleaning-Machine-Removal/dp/B07B48V7CR?th=1
Gord 🇨🇦
1954 1/2 ton 235 4 speed
The ones I've seen advertised on the web are priced under $50. Quite a difference (and likely a big difference in performance.) That's why I'm skeptical. Next time it pops up, I'll try to post a link. The ad says orders over $50 ship free.
Sir Searchalot
Sir Searchalot
$50 ????????? Don't think so. Rental??? Don't think so. $60,000 buys a lot of Evaporust. 2142.8 gallons to be exact.
37 GC #1427881 10/25/2021 12:44 PM
That sounds like a business investment versus home hobby/backyard mechanic. I seriously think I saw that it ships from China. We must recognize at that point that foreign countries don’t have US rules and regulations. Buyer beware!
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
Can't agree more. I did the raised eyebrow thing when I saw the link I mentioned. And yes it said under $50. I think it was very likely a scam or junk.
Ex Hall Monitor
Ex Hall Monitor
Interesting thread. I didn't know how much these things cost. In the name of research grin I g o o gled "laser rust cleaning gun" then clicked on "shopping". You can get them priced from $100 up to many thousands. I doubt the $100 model is option heavy. grin
Here's the ad I've seen. It just popped up again tonight.
All I have to say is Caveat Emptor. But if a couple of guys want to experiment and get the free shipping offer by buying two and report on it, that would be awesome.
Fiber Laser Cleaner Rust Remover
I have used the 50k versions and they work really well. The $50 ones are almost cheap enough to buy just to see what it is.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Looking online, it looks like if you order the fullsatisfy laser, you get a star of David necklace. They send it so there is a tracking number to give the credit card company as "proof" you recieved your item.
37 GC #1429155 11/04/2021 11:46 AM
Ex Hall Monitor
Ex Hall Monitor
Taking Kevin's link and scrolling down to the list of characteristics, #2 says output spot size is 4mm. If that means the working size cleaning area is 4mm by default that will take a LONG time to clean anything. 4mm is just over 1/8".
AD Addict & Tinkerer
I have always found that you get what you pay for! If it’s ridiculously cheap, it’s more than likely a scam!
Phil
Project Journals
Stovebolt Gallery Forum
Hmm, 4mm (.1574"). Yep, that would take a while to clean any large surface, but I was thinking about nicks and crannies on sheet metal where its darned difficult to properly clean. If it actually worked that would be a neat tool to have. I'm skeptical because the photos provided indicate a very large laser footprint on the items "cleaned". I read all 10 reviews and came away with the impression they were "fabricated" due to the word usage and order. Too good to be true? Yes I think so. Then again, it could be very useful for some very specific cleaning requirements if it actually works.
Ron - - Dusty53
1954 Chevy 3604
I didn't dig that deep into it, but suspected the videos they have up front were fabricated. I wasn't going to order one, because they'd charge a zillion dollars to ship it up here (~62 lb.) But I have blown in $50 on experiments before.
Thanks for digging into the "fine print", guys. I also was suspect about the "reviews". Most of them didn't even say anything of substance.
37 GC #1429230 11/04/2021 10:28 PM
$5.99 flat rate shipping to US! 62 lbs, really! WOW! I checked several scam websites and there was more than 10 reviews that stated they ordered the laser cleaner from “Fullsatisify”, and received either a cheap necklace or nothing at all with no way to contact them, so this is a total scam!
Phil
Project Journals
I went on the web for the cheap one. The reviews. I read said SCAM!
37gc In another life I worked in a diesel shop that had a huge caustic tank that we brought to a boil,it would really cut the gunk off of stuff. It was slow,we needed something faster for head work so built a much smaller 2ft x 3.5 ft. tank. It would heat up while your gutting and scraping the heads. Our local oilfield supply has caustic soda like you use in those tanks. That would be reasonable in price.
37gc info for you
Curmudgeon
Curmudgeon
I worked on Lasers that burned perforation holes in acetate filters. They work great but they need periodic expensive maintainance to keep them going. They work by evaporating most anything near the focal point of the beam. Same principle as seen in the video. Unfornutately things that get in the way like fingers and eyeballs can be evaporated as well. The material being evaporated may emit a gas so one should do their research in case the gas is toxic. Glass, glass-like materials and mirrors can pass or reflect the beam so Laser safety goggles are needed (eyes concentrate light and can burn from the inside). In the video I could see differences (depth of burn) when the laser was making a pass. Probably handheld. For more precision a holding fixture is needed that would insure the same distance between the laser and target are maintained. The warranty is only 2 years on the cabinet and 1 year on the fiber laser. One would hope the seller/manufacturer would supply refurbished swap-out parts at a disount to keep the laser working.
37 GC #1429779 11/10/2021 10:56 PM
It's all about the wattage, if they are stating it correctly
It is less about wattage than energy density. A 40W beam that is 7mm diameter will only slightly warm a piece of paper. That same beam focused to a 0.1mm spot will cut through 5mm hardwood.
Sure, the wattage is an important part of that equation, but only a part of it.
Fox Offline
Theyre probably an aerosol can that blows air hidden inside a fancy case.
“Use this to remove rust...dust!”
Keep your wallet closed in my opinion.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
37 GC #1429869 11/12/2021 12:59 AM
Thanks guys. That was fun, I knew the 50 dollar unit must be a joke or scam, but thought somewhere between the $50 and 50K there was something actually usable and someone that had used one. Evaporrust and the wire wheel for me! as for shipping I have bought phone screen protectors on Ebay for .79 and free shipping...How can they do that from China?
Larry
Wire wheels feel so archaic to me.
Moderated by  MNSmith
