6 members (Samantha, tclederman, TUTS 59, Otto Skorzeny, Mike Roache, Steelonsteel), 48 guests, and 4 robots.
Topics128,036
Posts1,055,458
Members48,422
#142975 06/15/2005 9:42 PM
What V8 was available in 1966 in a C60? Afriend of mine has a C60 grain truck and seems to think that it has a 327. I've only seen the engine once but it doesn't look like a 327 to me. Why does it have a double fan belt? What 2brl carb would have come on a V8 in 66? Thanks
#142976 06/15/2005 10:32 PM
327 was available in C60 starting in 64; double fan belt=heavy duty,some trucks had air pumps etc for the brakes; Rochester 2GC carb. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#142977 06/16/2005 3:09 AM
There were talldeck big blocks in 68, a 366 and a 427. I dont know if they were offered in 66 but I think the 366 was.
#142978 06/16/2005 3:17 AM
I had a '66 Chevy L60 series LCF, with a 366ci. Big Block. I also had a '64 Chevy L60H LCF, that was 327 equipted.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#142979 06/16/2005 8:08 AM
I'd imagine the 366 equipped ones would be pretty rare. I didn't think they had tall blocks until 67 or 68. Or maybe the 396 was introduced AFTER the tallblock version of the bigblock. Weren't they both derived from the 348/409 block?
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#142980 06/20/2005 5:36 PM
After 1965, Most all of the Heavy Duty 1966 Chevrolet trucks, came standard with the 366ci., big block, not the same block, as the old 348, & 409's. My '65 Chevy L80 Wrecker, had a 409ci. big block, & my '60 Chevy L80 Roadtractor, had a 348ci. big block, in it.
Spanky Hardy
1950 GMC 250 1-Ton
#142981 06/22/2005 8:57 AM
I remember the 348/409 block was angle cut at the deck surface,one reason they had pistons that weighed as much as a smallblock crank. Seems to me,though,that GM used the basics of the W-block as a model for the first big block engines;their first prototypes used some of the W block internal parts and a modified 409 block casting.(this is from stuff I read in an article about the history of the bigblock Chevy in "Hot Rod" magazine several years back,so I might be a little off on details.)
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
