| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | What V8 was available in 1966 in a C60? Afriend of mine has a C60 grain truck and seems to think that it has a 327. I've only seen the engine once but it doesn't look like a 327 to me. Why does it have a double fan belt? What 2brl carb would have come on a V8 in 66? Thanks | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | 327 was available in C60 starting in 64; double fan belt=heavy duty,some trucks had air pumps etc for the brakes; Rochester 2GC carb. Brian | | | | | Joined: Nov 2004 Posts: 122 Member | | Member Joined: Nov 2004 Posts: 122 | There were talldeck big blocks in 68, a 366 and a 427. I dont know if they were offered in 66 but I think the 366 was. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I had a '66 Chevy L60 series LCF, with a 366ci. Big Block. I also had a '64 Chevy L60H LCF, that was 327 equipted. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I'd imagine the 366 equipped ones would be pretty rare. I didn't think they had tall blocks until 67 or 68. Or maybe the 396 was introduced AFTER the tallblock version of the bigblock. Weren't they both derived from the 348/409 block? | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | After 1965, Most all of the Heavy Duty 1966 Chevrolet trucks, came standard with the 366ci., big block, not the same block, as the old 348, & 409's. My '65 Chevy L80 Wrecker, had a 409ci. big block, & my '60 Chevy L80 Roadtractor, had a 348ci. big block, in it. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I remember the 348/409 block was angle cut at the deck surface,one reason they had pistons that weighed as much as a smallblock crank. Seems to me,though,that GM used the basics of the W-block as a model for the first big block engines;their first prototypes used some of the W block internal parts and a modified 409 block casting.(this is from stuff I read in an article about the history of the bigblock Chevy in "Hot Rod" magazine several years back,so I might be a little off on details.) | | |
