| | | Forums66 Topics128,038 Posts1,055,585 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2021 Posts: 29 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 29 | New waterpump came with steel plate on the back but only one gasket . seems it must have a gasket between the steel plate and the waterpump housing, also the plate and engine block. Can I use black rtv between plate and waterpump housing?
1942 Chevy 1/2 ton 2014 RAM Truck
| | | | | Joined: Mar 2014 Posts: 4,480 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,480 | Usually the steel plate on the back side has been sealed at the factory. Was yours not sealed for some reason?
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Aug 2021 Posts: 29 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 29 | It was not sealed. I assumed wrong, but next time I'll look. thanks Jon G
