3 members (Gib70, Woodcmiami, Danielbolt), 318 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
I want to replace my bench seat with one that's more comfortable. Anybody have any suggestions?
Crusing in the Passing Lane
S-10 bench.
Ed
Didn't realize an S-10 bench would work in a cab like that. Is it a direct bolt in or is some fab. work required? My '59 is in dire need of a better seat. Is the height about the same as the old '59 seat?
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Rich, there is going to be some fab work to do, but your going to find that with every non stock seat you try. The S-10 seat has been used for many years as the go to replacement. Folks are beginning to experiment with 3 row seats out of later SUVs with some success. Many have the seatbelts built in. Take your measurements and head to the local Pick-a-Part yard.
Thanks guys. I have a 1991 Chevy S10 that I was going to scrap so I'm definitely going to pull the seat first.
Chevies till Id Iv'e always thought the originals were comfotable,learned to cover them (at home) with kinda stiff canvas type material so you can slide on it a little.
The original seats ARE comfortable, as long as the springs aren't broken or collapsed. I don't know the condition of the OP's seat, but that's the reason I need to repair or replace mine.
Rich
1947 Loadmaster
Could I fit a 1968 Chevy truck bench seat? I have a good one. My s-10 has buckets seats and I need a bench seat. As a last resort I can use the padding and burlap from the 68 Chevy, might even be able to use the cloth. I have hog ring pliers and rings. I could always hand sew the cloth to fit.
Rich's Toys Go to your local auto upolestry shop they should have springs new in burlap you can use to fix your seats.
Thanks! I plan to look into that next spring, as the truck is currently in storage for the winter. But just weighing all my options for now.
Rich
1947 Loadmaster
Rich's toys You should put your seats on your bench and fix them this winter while your waiting.
We'll see how much time is left after I finish the projects that are already in there! grin
Rich
1947 Loadmaster
Rich's Toys My posts are crazy illusive,suggested you should get them on your bench for the winter. Nice thing about AD seats they aren't hog ringed so you work on padding and springs pretty easily. Wife sews mine up,have cardboard patterns made from old seat covers so once they're sewed- up you can put em on anytime. Even learned to turn em wrong side out on beaters turn around and wear out passenger side before you junk em and start over.
Will a seat out of a 1955-1956 fit my truck?
Break out your tape measure...the '56 seat is 56" wide with the tape laying in the middle of the seat bottom and the cab is 61" door to door measured at the same place.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
