6 members (Otto Skorzeny, R&S 51 GMC, KEVINSKI, Bill Hanlon, Swami29, Phak1), 100 guests, and 0 robots.
Topics128,125
Posts1,056,339
Members48,440
#1429282 11/05/2021 2:36 PM
I bought a new clip for the clutch fork ball because the other had been kind of flattened when trying to get it over the ball.
Does the new one go in the clutch fork with the curvature "up" and away from the fork? Get what I'm saying?
Thanks.
yes
Thanks! Seemed like it should go in that way but......
This way.
Thanks Lug. That's the way that seemed logical to grasp the ball but it's nice getting confirmation from you and RFS.
Does the clip just hold the fork socket into the ball until the clutch pedal linkage, throw-out bearing and tranny are put together? It doesn't seem like the clip is a wear and tear part.
The clutch fork is held in place in the socket with that spring and is a pivot point every time the clutch is pushed in. All of those components are potential wear points and the spring can break. Put a small amount of grease on the contact points when you assemble them.
Fred
The spring just keeps the ball in place and doesn't really have any load on it when the clutch is pushed in. That load goes into the socket on the bell housing, which can wear. Definitely grease that socket and the ball.
