6 members (fonz8261, klhansen, TUTS 59, Hotrod Lincoln, Geo55, Gdads51), 122 guests, and 3 robots.
Topics128,165
Posts1,056,989
Members48,458
#14288 11/03/2003 11:40 PM
does anyone know of a lift kit available for these trucks any help would be apppreciated, thanks
I thought there was just sping blocks for these or new springs. Nothing special. Did you check your local 4X4 shop?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33585&item=2441367048
I didn't know if there was a kit for sure or not. I was just going to get some aluminum block and raise it a little. Thanks
Remember there is pins in the springs the mount into the perch on the axle. I would not recomend making your own blocks. besides your bolts will no longer be long enough. The kits are pretty cheap.
Good luck..
Brent
That is good to know thanks Brent
