| | | Forums66 Topics128,154 Posts1,056,834 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14288 11/03/2003 11:40 PM | Joined: Nov 2003 Posts: 13 Member | | Member Joined: Nov 2003 Posts: 13 | does anyone know of a lift kit available for these trucks any help would be apppreciated, thanks | | |
#14290 11/06/2003 11:24 PM | Joined: Nov 2003 Posts: 13 Member | | Member Joined: Nov 2003 Posts: 13 | I didn't know if there was a kit for sure or not. I was just going to get some aluminum block and raise it a little. Thanks | | |
#14291 11/07/2003 3:29 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Remember there is pins in the springs the mount into the perch on the axle. I would not recomend making your own blocks. besides your bolts will no longer be long enough. The kits are pretty cheap.
Good luck..
Brent | | |
#14292 11/07/2003 8:20 PM | Joined: Nov 2003 Posts: 13 Member | | Member Joined: Nov 2003 Posts: 13 | That is good to know thanks Brent | | |
