2 members (Gdads51, moparguy), 96 guests, and 2 robots.
Topics128,180
Posts1,057,068
Members48,460
Former Workshop Owner
Saw this for sale last Friday on craigslist. Called up the 86 year old retiring farmer and he said he's dropping the price because it's leaking brake fluid. I said "I'll take it". Drove out to get it today. After the seller filled the master with stop juice I drove it home 35-40 miles. He obviously had been doing this for awhile as he had a step stool ready and topped it off in less than a minute. He also guaranteed me that it would stop as long as I pumped the brake pedal. It was an interesting slow, but way slower than normal ride home. All the way I was hoping that no one would brake hard in front of me and I was always looking for a soft target just in case.
Here are the symptoms, 1st pump on the pedal nothing, second pump slight braking and 3rd pump great stopping power although pedal almost on the floor. Brake fluid leaking inside the cab directly below the pedal. My first plan is to rebuild or replace the master cylinder. Hopefully that is all it needs.
Anyway, here she is. Nothing to brag about, but it has a 350 V8, four speed with a two speed rear end, power steering and like new tires. Although it is little rough, I only need a work truck and not a show vehicle.
My C50 pic 1
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Nice score.
Crusing in the Passing Lane
Nice!
Ed
Nice truck!
If it were me I'd replace all of the steel and rubber lines when I replaced the MC...those lines are 50 years old now and fail from the inside out...easy to do.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Nice truck! Congratulations!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Big Bolt Forum Moderator
nice looking truck, and ditto on replacing all of the steel and rubber lines! I would also at least put kits in all of the wheel cylinders. I think I got the ones for my 58 from Rock Auto, for about 5$ per cylinder.
Mike
A complete brake rehab will be some of the cheapest life insurance you'll ever buy- - - - -both for yourself and the people who share the road with you. It will also keep some ambulance-chasing lawyer from taking everything you own in case of an accident.
Unconventional Thinker
Nice score. I see a brake job in your future, but it will be worth the money, time, and effort. Grandpa had a '63 C50, it was a cool truck to drive and operate. Mainly used it when the backhoe was needed.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
If you can find new cylinders, it is not worth the labor to reuse the old ones.
Ed
