0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
#1428647 10/31/2021 6:43 PM
What has to be done to get dual zenith set up? I have a friend that wants to fun a matching set on a 270 gmc.
Gmc101 #1428663 10/31/2021 8:51 PM
Curmudgeon
Curmudgeon
"I have a friend that wants to fun a matching set on a 270 gmc." Typo?
Fun? Do you mean "find" a matching Zenith set or "have fun" making a matching Zenith set?
If you want to buy a matching Zenith set then Stovebolt rules say you must post your request in the Truck Parts Wanted Section.
If you need information on how to create/build your own dual matching Zenith set, I would start my education journey here:
https://www.thecarburetorshop.com/Multiplecarburetion.htm
Gmc101 #1428673 10/31/2021 10:21 PM
Carburetion specialist
If "fun" is a typo for "run"; 95 percent of the work in tuning multiple carbs is in the selection of the carbs.
Please observe the second line in my signature block.
Jon.
The Carburetor Shop
Gmc101 #1428700 11/01/2021 12:54 AM
My self I am running a matched set of holley AA- 1 on a large port nicson on a mild GMC 302 with a cam, head work and dual exhaust it was a pain but got it to work.
I have a matching set of zenith 646087 10596A that are on a old gotha intake that he wants to run on a his GMC 270. My self I know very little about zenith carbs ! There in good shape but will need kits. He has a ellis intake he will be running. I will never use them so I was going to give them to him to help a fellow rodder out. I would like to see some one get some use out of them.
I know he will need to heat the intake to get it working but I know nothing about zenith carbs so can they be maid to work or are they just paper weights ? They have no adjustable main jet. I have never had them apart so I don't know main jet size. Can they be maid to work ?
Gmc101 #1428720 11/01/2021 2:50 AM
Thanks for posting the tag number!
They can be made to run. How well they can be made to run is an entirely different story.
Jon.
The Carburetor Shop
buoymaker #1433085 12/11/2021 4:19 AM
buoymaker Gmc101 meant to say run
