6 members (Tronman, DougH6100, MikeStone1953, Wally / Montana, Steelonsteel, 1 invisible), 166 guests, and 3 robots.
Topics128,201
Posts1,057,279
Members48,466
#1428551 10/30/2021 10:41 PM
I have a leak where the drive shaft attaches to the rear differential. Unhooked the drive shaft and exposed a bolt with a large nut on it. It also has a cotter pin through the nut and bolt, which i have been able to remove. I can't get the nut to loosen at all. I went and bought a socket to fit, but is too wide to fit in the space. I end up turing the wheels instead of loosing the nut. Am i doing this wrong?
1949 chevy 3600
First attempt at restoration
Crusing in the Passing Lane
That nut requires several hundred pounds of torque to tighten, so will be hard to remove. I use a 48” pipe wrench across the U-joint to remove and tighten, so grind on your socket to fit properly to prevent an accident. Get a proper wrench to remove.
Ed
Thanks Ed.
1949 chevy 3600
Doesn't take much time to make a jig to hold the yoke with a few feet of flatbar. Just need two holes drilled the same distance as the u joint strap holes, rest end of the jig on the floor. Makes the process a bit easier and safer.
If you know someone with an air impact or the big milwaukee electric impact, it will be a lot easier to remove
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
Bought an impact driver and the nut came right off. I also removed the washer, but now am stuck. I can't get the yolk off to get to the seal. What am i doing wrong?
1949 chevy 3600
Riding in the Passing Lane
It might come off with a big hammer from the rear. If not you will need a puller.
George
1972 Chevy c10 Cheyenne Super
I used a cheap puller.
Mike Barnes
1950 GMC 1-ton pickup
Moderated
Moderated
Do you know where I could get one of the pinion nuts?
I have a 1949 GMC 3/4 ton.
Tony Siebers
