1 members (KEVINSKI),
160
Mod | | | Forums66 Topics128,108 Posts1,056,230 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | I picked up an SM318 3-speed transmission yesterday and want to clean it up both outside and inside before I install it. After I drain it, would there be any harm in filling it with either diesel or gasoline, slosh it around, and then drain it? I’d like it to be as clean as possible before I refill it with clean transmission oil. Thanks
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Mar 2007 Posts: 3,397 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,397 | Diesel fuel should work just fine, it won't leave a lot of residue or varnish. If it's really nasty you may want to soak it in a solvent tank.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | I didn’t know if diesel or gasoline would damage anything inside like seals or bearings. I’ve never been inside a tranny before. Thanks
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Diesel is less volatile and safer. Of course, still use it outside with plenty of ventilation.
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Fill with Diesel and use a big drill motor to spin the input shaft. Drain and refill with 90 weight GL-1 lube, not some super slippery synthetic Jerry
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Thanks Jerry. Sure glad to see you’re back and making comments again in the Forums! Glad you’re feeling much better!!
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Mar 2011 Posts: 65 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 65 | You could bring it to a machine shop and have it hot tanked. Had a shop do an intake manifold once and it looked new. Just no aluminum!
1951 1/2 Ton 216ci 4spd 1955 3/4 Ton NAPCO 235ci 4spd 1959 1/2 Ton stepside 235ci 4spd
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | The Oakite solution that was once used in hot tanks is illegal these days due to "environmental" panic. The greenies will trump up huge fines for anyone who tries to use any sort of an effective hot tank cleaner, so those tanks have been replaced by industrial strength motorized pressure washers that use something resembling commercial dishwasher detergent. The trans would have to be completely dismantled to benefit from that kind of cleaning.
Oakite and similar caustic hot tank chemicals would eat the brass and bronze parts of the transmission, even if you could find someone who still operates a hot tank illegally.
| | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | I've used stuff called Oil Eater in a small parts washer. It's mixed 1:10 with water and does a reasonable job. But I think it's citric acid based, which probably wouldn't do for an assembled tranny.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2007 Posts: 3,397 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,397 | If you really don't want to disassemble the trans just pull the cover and spray it out with several cans of brake cleaner. It will take all but the heaviest crud off and still won't leave a residue. like the others here I would recommend replacing the seals while your this deep in it.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | The owner's manual for my '47 Diamond T recommends using diesel fuel to clean out the tranny and differential when changing gear oil (on the truck). The tranny is a Warner T-9, non-synchronized four speed. I would not recommend gasoline for the safety reasons. Kent | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Mineral spirits works fine, too.
Ed
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | I put mine right in the parts cleaner. Got it from a friend and looked like he found it in a creek. Been using it for 5 years sinced cleaned out. Works good. | | |
