| | | Forums66 Topics128,052 Posts1,055,774 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | I was thinking of painting my firewall and later i will paint the truck . the paint shop suggested acrilic urathane. My daugerter wants the truck to be kipton green like the new 2018 camaros. Do i need a special gun and what size Tip should I use? Also the paint has a slite metalic to it.I have painted soild colors with the gun I have and it came out good.
| | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | 29Tons - When you purchase the paint, they should give you a Technical Data Sheet that will provide what size tip is recommended, same goes for primers, etc... If they don't give you one, ask for one. Also you can go online and search and find technical data sheets for most popular paints. I'm no expert myself, just an amateur, but I like the gravity HVLP type guns.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Do you mean Krypton Green and acrylic urethane?
I was a kid when I worked in a body shop so take what I say with a little seasoning.
The paint would not be original so, in my humble opinion, spray the firewall a good generic black. That way if the green is regretted later on at least you don't have to redo the firewall. It's difficult to keep overspray off an engine, wires, cables, hoses and other parts.
Also you need a good experienced body man to spray the truck. Solids are easier but metallic paint, especially on big rounding fenders, can run (collected metallic particles) that can be seen (the reflection) by the eye even though the surface is smooth. Maybe modern paint today doesn't have that problem. If it runs, you can try to let it dry up to maximum limit, then spray another coat. Fingers crossed it doesn't run again.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | When I was a lot younger and painting I would keep a couple of marbles or bearings in the gun and that would help keep the metallic from settling. However I haven't painted in a few years Dan | | | | | Joined: Feb 2018 Posts: 167 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 167 | I like the look of a painted firewall. The SPI (southern polyurethane inc ) forum is a great resource for paint. Not sure what year truck you have but the running board apron on AD truck has been my practice piece. | | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | Im working on a 41 Chevy coe its going to be a pickup body on the back also will be a hot rod so not being an original color is not a problem. I sprayed a metalic paint in the 80s and was having a problem with the metalic getting stripes in the paint. I have heard of putting steel balls in the paint gun when i used a suction style gun but with a hvlp gun wouldnt that clog the hole up were the paint to goes through?
| | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | Spraying metallic paints is more technique than the separation of the flakes. Watch a few YouTube videos and practice on a few panels before you attempt spraying your truck. One of the better ones is by Kevin Tetz. [LINK]
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | I have heard of putting steel balls in the paint gun when i used a suction style gun but with a hvlp gun wouldnt that clog the hole up were the paint to goes through? It would depend on the size of the steel balls. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I've used marbles for the same affect.
Dennis
40 Chevy 1/2 ton
