| | | Forums66 Topics128,006 Posts1,055,267 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 33 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 33 | I have a guide spot light on my 52 pickup. Went to replace the bulb, and the gasket around the lens disintegrated . Does anyone have a source for this gasket/seal, or what to use in its place? Thanks..Tommy | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | No experience with the spot light but I had an old siren/red light combo that the cork gasket had failed. I found that, in that instance, the rubber screen window spline fit the channel and sealed OK. You can buy different sizes of spline. It may or may not work for a spot light.
| | | | | Joined: Aug 2007 Posts: 33 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 33 | No experience with the spot light but I had an old siren/red light combo that the cork gasket had failed. I found that, in that instance, the rubber screen window spline fit the channel and sealed OK. You can buy different sizes of spline. It may or may not work for a spot light. Thanks Tiny..I will investigate that. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | If you google "Guide spotlight lens gasket" quite a few choices appear.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Aug 2007 Posts: 33 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 33 | If you google "Guide spotlight lens gasket" quite a few choices appear. Well, I'll be..I googled the heck out of guide spotlight parts, and the gasket never showed up. Thanks for that info. | | |
