4 members (baldeagle, John L., Joe H, 1 invisible), 106 guests, and 1 robot.
Topics128,014
Posts1,055,330
Members48,419
#1427696 10/23/2021 3:44 PM
I have a guide spot light on my 52 pickup. Went to replace the bulb, and the gasket around the lens disintegrated . Does anyone have a source for this gasket/seal, or what to use in its place? Thanks..Tommy
tommyleea #1427699 10/23/2021 4:01 PM
Ex Hall Monitor
Ex Hall Monitor
No experience with the spot light but I had an old siren/red light combo that the cork gasket had failed. I found that, in that instance, the rubber screen window spline fit the channel and sealed OK. You can buy different sizes of spline. It may or may not work for a spot light.
Tiny #1427708 10/23/2021 5:11 PM
Thanks Tiny..I will investigate that.
tommyleea #1427759 10/24/2021 1:51 AM
If you google "Guide spotlight lens gasket" quite a few choices appear.
Craig
cmayna #1428032 10/26/2021 2:54 PM
Well, I'll be..I googled the heck out of guide spotlight parts, and the gasket never showed up. Thanks for that info.
