4 members (Gray_Ghost, 3B, Woodcmiami, lumbersawyer), 313 guests, and 2 robots.
Topics128,152
Posts1,057,011
Members48,460
Have a chance to buy a 235 1955 GMC motor was told it is 2" longer than the 216 that is in there now will it fit without a lot of screwing around? And can some of the parts from the 216 work on the GMC motor? Any help would be great. Thanks!!! 1-262-392-2989 or [email protected]
Marv.
Crusing in the Passing Lane
GMC never had a 235, 228 was the smallest, full oil pressure engine. SN stamped on machined pad behind distributor starts with displacement, I. e. 228xxxx. GMC should bolt right up to your Chevy bell housing, etc. GMC engines up to 302 will all look the same.
Ed
Eagle, Wisconsin hmm?? Maybe Canadian GMC 235 ??
Easy L6 ID:
Chevrolet 216, 235, 261 has 2 engine block core plugs on the left (driver's) side
Chevrolet 194, 215, 230, 250, 292 has 3
GMC 228, 236, 248, 256, 270, 302 has 5
Not if 228xxxx is in the Engine Serial Number?
228 cubic inches
The other number I got from the guy was F248310356G. I still need to know is a GMC motor longer than a Chevy 216 block by how much. Thanks!!!
Marv.
The F248 will be a GMC Engine. Yes, GMC engines are about 2” longer than Chevys. It will require moving the radiator forward.
