8 members (TUTS 59, wilbur53, Joe H, tclederman, Charles in CA, kades51, 2 invisible),
74
7
Mod | | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | Have a chance to buy a 235 1955 GMC motor was told it is 2" longer than the 216 that is in there now will it fit without a lot of screwing around? And can some of the parts from the 216 work on the GMC motor? Any help would be great. Thanks!!! 1-262-392-2989 or [email protected]Marv. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | GMC never had a 235, 228 was the smallest, full oil pressure engine. SN stamped on machined pad behind distributor starts with displacement, I. e. 228xxxx. GMC should bolt right up to your Chevy bell housing, etc. GMC engines up to 302 will all look the same.
Ed
| | | | | Joined: Apr 2010 Posts: 245 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 245 | Eagle, Wisconsin hmm?? Maybe Canadian GMC 235 ?? | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Easy L6 ID: Chevrolet 216, 235, 261 has 2 engine block core plugs on the left (driver's) side Chevrolet 194, 215, 230, 250, 292 has 3 GMC 228, 236, 248, 256, 270, 302 has 5 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Eagle, Wisconsin hmm?? Maybe Canadian GMC 235 ?? Not if 228xxxx is in the Engine Serial Number? 228 cubic inches | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | The other number I got from the guy was F248310356G. I still need to know is a GMC motor longer than a Chevy 216 block by how much. Thanks!!!
Marv.
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | The F248 will be a GMC Engine. Yes, GMC engines are about 2” longer than Chevys. It will require moving the radiator forward.
