2 members (Thomaslb, Eddie54), 166 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
I installed a PCV valve on my 1957 235 on top of the draft tube and routed the tubing over to where the wiper connection normally is on the intake manifold. Since this engine will operate in a dusty environment, being installed in a forklift, I wanted to do something better than the breather oil fill cap for air intake to the crankcase. I’m also installing a 14” diameter by 2.5” tall modern air cleaner in place of the old oil bath filter. I’m planning on offsetting the 14” air cleaner such that it resides over the carburetor and cantilevered over the valve cover. A brace would be a 3/8 NTP tube that would connect and provide an air path from the valve cover to the air cleaner. My question is would the amount of vacuum within the air cleaner be small enough compared to the intake manifold vacuum such that they don’t cancel each other out and make the PCV valve ineffective?
Any words of wisdom would be appreciated.
Thanks, Paul
1944 Chevy Army Truck and 1957 Chevy
"From out on the Farm"
7
7 Offline
As long as the filter isn't too restrictive from dust you should be fine.
Moderator, Electrical Bay
Hi Paul,
The best thing would be to run your PCV intake into the clean air portion of your air cleaner. Sounds like you already know this, but you want the air being sucked into your engine to be as clean as possible or all is for naught. I have roughly the same size air cleaner as yours. I used a non-vented filler with a grommet on top (which in my case is where air enters the engine) and ran a hose from there right under the air cleaner to a fitting I installed under it. The amount of vacuum inside the air cleaner (unless you have one of those odd little tuna can-sized filters) won't matter at all. Good luck.
~ Jon
Farmer Paul, You should read this. It's a carefully researched PCV upgrade solution specifically for this engine. It's complete with theory of operation, measurements of vacuum pressure, photos, and instructions how to do it yourself, or you can purchase a complete conversion kit with pre-bent steel vacuum line, the correct pcv valve for this engine, grommets, etc.
By the way, the recommended port is exactly where you installed - the wiper port on the intake manifold.
Instructions to make it yourself and theory of operation: http://devestechnet.com/Home/PCVInstall
Custom Made Kit:
http://devestechnet.com/Services/PCVUpgrade
1950 Chevrolet 3100 (Ol' Roy)
