| | | Forums66 Topics128,047 Posts1,055,662 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 12 New Guy | | New Guy Joined: Nov 2004 Posts: 12 | I have a 1933 1-1/2 ton truck that used to belong to my grandfather. I am just getting started on the restoration. I want to keep the truck original looking, but want to update the drivetrain. I would like to swap the 207 for a 235 with a synchronized tranny and open driveshaft. Has anyone ever done a swap like this?
Thanks | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | excellent your keeping a family heirloom. Hopefully some of the more experienced bolters will be along with advice on the changes. | | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | there may be a way to keep the closed type drive shaft and still get newer moter and trany my 39 parts truck has closed drive line with old non syncro trany but it has a cracked 235 bolted in. also and the newer muncie 420 was avilible in some ('torq tube' pickup trucks Im thinking it was in the mid 50s ) | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I replaced the old non Synchro Transmission on my 46 3/4 Ton Panel with an SM420. I needed a different bell housing to make the link to the 235. My guess is that if you find a later model 235 driveline it should be fairly easy. The problem you will most likely run into will be the mounting of the clutch and brake pedals.
I would suggest finding an engine, bell housing and SM 420 driveline and take the pedal system as well. I think you can use your original pedals and the newer mounting system to keep the orignal look. You also need to have the front drive shaft shortened. The SM420 is much larger than the stock Trans.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Nov 2004 Posts: 12 New Guy | | New Guy Joined: Nov 2004 Posts: 12 | Thanks for the information everyone. I live in Colorado - out in farm country, so AD trucks are readily available for parts. I think it's a requirement that every farmer has to have at least one 47-54 truck setting out in the yard. I'll make sure I check on the pedals - I didn't even think of problems there. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I would also suggest measuring the length and other dimensions of the engine and drive train to confirm what will and will not line up. The length of the 235 and what you have now will probably be different. The length of the water pump is a routine issue to be dealt with, as are the locations of motor mounts..
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Apr 2000 Posts: 28 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 28 | I believe one of the vendors, maybe jim carters, is offering a modified bell housing for this swap. i remeber researching the same thing for my 46 3/4 Phil | | | | | Joined: Nov 2004 Posts: 12 New Guy | | New Guy Joined: Nov 2004 Posts: 12 | I tracked down a 1950 1 1/2 ton Chevy truck, with a newer, rebuilt inserted engine. I measure the frame widths and spring hangers on my 33 and this 50, and they are nearly identical. I am planning on swapping out the entire drivetrain in my 33. Best of all, the 50 parts truck only cost me a couple of cases of beer. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Congratulations, sounds like a great score!
Phil, is right about the bell housing, Jim Carter sells them and they work fine. That is what I used.
How about a picture!
