| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 67 | I was able to go get the '50 4100 and bring it home last night. It didn't go too bad. Now I can't wait to get home and give it a good look over. The VIN on the door pillar is: 1TJ-E 1345. Can anyone decode that? The engine appears to be a later 235 with an 848 head on it, but I will find out for sure once I can get things cleaned up and read more of the numbers.
The owner gave me a full set of brand new brake shoes with four wheel cylinder rebuild kits and new rear axle seals with it too. | | | | | Joined: Sep 2000 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 67 | Well the engine casting number is 3837004, which I come up with as a '55-'57 235/261. All the clues are pointing to 235. The number behind the distributor appears to have 2 different numbers stamped one over the other, and the predominant one appears that it might match the title. I found a decoder for the VIN and it comes up as a '50 4100 series (1-1/2 ton) 137" wheel base built in Flint in the month of May.
Some of the wheels are looking a little spooky also. I know that Chevy used these same ones for a while, so I can probably dig up some better ones, but this might also be a good time to change out to a different kind of wheel. I am not real fond of the split rims, but as long as they are in decent shape they don't bother me too much. Are there other wheels available out there, used or new, that could be used? | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Late model 10-lug 19.5" wheels are one piece, and bolt right up, BUT, the center hole is slightly bigger. In 54 and up the whole is exact, I had them on my 54 2-ton. You can then run 8r 19.5" radials, makes better ride and handling. Not much smaller in diameter than 20" either. I was always going to experiment with having a small 1/8" square ring made on a lathe to tack into wheels to fit on hubs closer. The weight is supposed to be carried on the hub, not studs. BUT, if you use the trim rings available in 5 lug for front and 10-lug for back wheels, I think you could spread the tension around enough to run those new wheels fine. I have seen later model splits on many junkers I brought home, and mixed styles, didn't seem to be a problem for many years. Delivery trucks, motorhomes and the HD3500 Super Duty 1-ton Chevs have those wheels. Even up to last years models. Check a big truck or ag tire store for used.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Sep 2000 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 67 | Thanks for the tip on the wheels, I might have to start looking around a bit.
Aaron | | |
