Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (tclederman, rfs56trk, Woogeroo, Peggy M, 1 invisible), 48 guests, and 6 robots.
Topics128,010
Posts1,055,299
Members48,419
#1425991 10/06/2021 1:48 AM
i need pics on where the wires go. i have looked all over and don't have the right way to install the wires. i tried and made the needle to go on the negative side. so i stopped before something breaks. any help will be nice. p.s. it has three studs two has a fuse between them and the other is to the right
robert b #1425992 10/06/2021 1:54 AM
Nobody will be able to help unless you tell us what you’re working on. Year, model, stock or not??
robert b #1426025 10/06/2021 12:36 PM
sorry 1937 gmc truck with 1998 4.3l engine
robert b #1426036 10/06/2021 2:35 PM
Is the amp gauge from 1937 or 1998?
Probably the earlier.
robert b #1426098 10/07/2021 1:00 AM
it's rebuilt to fit the 1937
robert b #1426456 10/10/2021 8:40 PM
if you still need help I can take a picture of mine (1936) gmc converted to work with a late style GM motor
1936 GMC T-14 restro-mod
robert b #1426481 10/11/2021 12:44 AM
yes please
robert b #1428581 10/31/2021 1:05 AM
fast55 will you post the pics on the amp gauge. thanks
robert b #1428710 11/01/2021 1:58 AM
Crusing in the Passing Lane
If the amp gauge reads neg. when you turn on the headlights with engine off, it is correct, if it reads pos., it is just backwards, switch terminals. The amp. gauge he just reads which way the current is flowing, and how much, roughly.
Volt gauge just reads how much!
Ed
robert b #1428730 11/01/2021 12:03 PM
You may want the amp gauge for decoration if using an alternator. The amp gauge may not handle the amperage that the alternator can put out.
There is a way to make a shunt so that a small amount of the current goes through the gauge, and it has been a long time since I did that. But I've seen amp gauges fail when a generator was replaced with a high amp alternator
robert b #1428745 11/01/2021 1:19 PM
AD Addict & Tinkerer
I installed a shunt as recommended by HotRod Lincoln. Here is the link to my post on how I did it. https://www.stovebolt.com/ubbthread...link-for-12v-alternator.html#Post1310217
Phil
Project Journals
Stovebolt Gallery Forum
