| | | Forums66 Topics128,050 Posts1,055,673 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 20 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 20 | i need pics on where the wires go. i have looked all over and don't have the right way to install the wires. i tried and made the needle to go on the negative side. so i stopped before something breaks. any help will be nice. p.s. it has three studs two has a fuse between them and the other is to the right | | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | Nobody will be able to help unless you tell us what you’re working on. Year, model, stock or not??
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2020 Posts: 20 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 20 | sorry 1937 gmc truck with 1998 4.3l engine | | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | Is the amp gauge from 1937 or 1998? Probably the earlier.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2020 Posts: 20 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 20 | it's rebuilt to fit the 1937 | | | | | Joined: Oct 2012 Posts: 335 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 335 | if you still need help I can take a picture of mine (1936) gmc converted to work with a late style GM motor
1936 GMC T-14 restro-mod
| | | | | Joined: Jun 2020 Posts: 20 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 20 | | | | | | Joined: Jun 2020 Posts: 20 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 20 | fast55 will you post the pics on the amp gauge. thanks | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If the amp gauge reads neg. when you turn on the headlights with engine off, it is correct, if it reads pos., it is just backwards, switch terminals. The amp. gauge he just reads which way the current is flowing, and how much, roughly.
Volt gauge just reads how much!
Ed
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | You may want the amp gauge for decoration if using an alternator. The amp gauge may not handle the amperage that the alternator can put out.
There is a way to make a shunt so that a small amount of the current goes through the gauge, and it has been a long time since I did that. But I've seen amp gauges fail when a generator was replaced with a high amp alternator | | |
