| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 7 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 7 | Hello all, I have a 1933 Chevrolet 1 1/2 ton type 0 with a Heil mechanical dumpbox. I would like to put a weight limit sign and been having trouble finding a empty weight for the truck and capacity weight went thru the 33 shop and owners manual and found nothing nothing any ideas???? | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | Brad You might be able to find the empty weight of your truck by just going to a gravel pit and having it weighed. Hope this helps for part of it. Welcome to the bolt. Jim | | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,989 | I was also going to suggest finding a scale somewhere and having it weighed. Any weight figures you might find in a book would only pertain to the truck itself anyway and probably would not include the box, as those are aftermarket and all are different. So the only way to find the true weight of your particular truck would be to have it weighed somewhere. | | |
