0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#1426035 10/06/2021 2:20 PM
What would you estimate this dump body weighs? The body portion only, not the sub frame or hoist mechanism.
I want to remove the dump body, keep the hoist part and install a flat/stake body. Thinking of getting a gantry crane to perform the task and wonder if a 1 ton crane will be big enough.
Tag on the dump body says it's Garwood Industries, Model Number GA-2, 4 yd capacity. Approx. dimensions - 8' long - 7' wide - 2' tall
I see modern Knapheide 4yd models are in the 1,700-1,800 weight range, but have much shorter side and back rails
DougH6100 #1426248 10/08/2021 12:49 PM
7
7 Offline
I would guess 2000 lbs ish
Moderator
Moderator
2 Offline
I would guess 1500 to 2000 lb
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
That is what I was guessing, it can't imagine it would be more than 2,000 lbs.
A Big Tex 70SR tandem axle dump trailed with 5'x10' bed weighs just under 1,800 lbs, and that if for the entire trailer.
