5 members (Wally / Montana, 3B, GMCJammer51, Shade Baby, greenie-reddy), 71 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
#142581 05/11/2005 10:32 PM
Apprentice
Apprentice
fIRETRUCK RUNNING WARM TO PARADES SO I WAS GOING TO REPLACE THE THERMOSTAT
THERE IS A 3 INCH DIAMETER TANK ABOUT A FOOT LONG ON TOP OF THERM HOUSING WITH THE TOP RAD HOSE GOING TO IT
WHAT IS IT AND HOW DO YOU REPLACE THERM
THANKS
#142582 05/11/2005 10:59 PM
Sounds like an expansion tank and the thermostat should be inside the gooseneck/therm housing, i.e., the usual place.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#142583 05/12/2005 4:59 AM
Are there any other hoses connected to the foot long tank? If yes, it could be a heat exchanger used to help cool the engine when pumping/drafting.
While replacing the T-stat remove the upper and lower radiator hoses and back flush the radiator with LOW perssure water. DO NOT allow the water hose to make pressure or you will burst the seams...5-10 psi MAX. See what comes out!!
smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
#142584 05/13/2005 4:03 AM
No thermostat will also make it run hot on the highway.
