0 members (), 123 guests, and 5 robots.
Topics128,078
Posts1,056,035
Members48,433
#1425705 10/02/2021 1:23 PM
Got the rear done moved to the front previous owner did no brake work on the truck and was driving it. The front brakes were not working at all wheel cylinders were froze.
I ordered new wheel cylinders,shoes,grease seals and brake hose. Parts should be here early next week gettin close to being on the road.
[img]https://imagizer.imageshack.com/img922/3042/ahW3aI.jpg[/img]
Got the front left side apart wheel cylinder off it was full of rust and froze solid hasnt worked is a really long time. Cleaned bearings and backing plate waiting on parts.
[img]https://imagizer.imageshack.com/img924/3224/YyibKW.jpg[/img]
https://imagizer.imageshack.com/img922/6199/m92Po4.jpg
Well the passenger side drum has some groves cut pretty deep hopefully they can be turned. Looks like they ran the pads to long and the rivets got the drums and they just put new pads and chewed the pads up. I wonder if the drums are available new or used. Gonna take them to get turned Monday so wish me luck.
Drums all day long at your local auto parts store. Buy new if yours are bad
~ HB
1962 Chevrolet C10
1962 Suburban
Hambone #1425736 10/02/2021 9:04 PM
For a 67-c-50?
There are folks here using drums with grooves in them. If they turn them down to far, you could be stuck with no brakes.
1951 1 Ton Completed
I am gonna tell them to not go down more than allowed.
3B Offline
Hy wickedinhere, there are two different front brake drums listed for 1967 C50 with Kelsey wheels, depending on which front axle is in your truck. Could you please tell us how many holes are in your brake drum?
I think i have the 5000lb front axle drum looks like it has 12 holes and uses six holes that bolt to hub.
I got the drums turned this morning at a big truck machine shop,the drums have never been turned so there was plenty of meat to turn.LOLdrum
Oh man they look amazing.
3B Offline
Hy wickedinhere, glad to read your front brake drums were turnable.
Hambone #1425899 10/05/2021 1:46 AM
Yup completely missed the c50 part. Glad you got them worked.
~ HB
1962 Chevrolet C10
1962 Suburban
I have the 7000lb front axle which has 14x2.5" drums. They seem to be made of unobtanium :-( Been running them a bit oversize on my C60 since the '90s, I've never been able to find a pair.
Got the drivers side done and 24.5 wheel installed on to the other side tomorrow
oo
Well got most of it done went to change the brake lines and the hard lines started leaking they are rusted and very brittle. Off to the parts store for new lines will change them all while i am at it.jkj
Man Good thing i decided to change all the lines they were rotted then someone used 3 regular compression fittings on the rear brake lines. When i got it all back together could not get a good pedal so i went and got the bleeder that hooks up to the compressor and bam that did the trick well worth the money. I am gonna bleed one more time then road test wish me luck.LOL
3B Offline
Hy wickedinhere, your picture of your assembled brakes appears to show two brake shoes with the same amount of lining on them. I believe your brakes should have a primary and secondary shoe setup. The primary shoe which mounts towards the front of the vehicle has shorter brake lining than the secondary brake shoe has. Please check to make sure you don't have one side of the truck with two secondary brake shoes and the other side with two primary brake shoes.
wickedinhere Now if that shop can arc your shoes brakes will work like new ! I know you hate to see them grind away new lining but the ills of letting them wear-in are bad too !
