3 members (55shaker, JW51, Gdads51), 147 guests, and 1 robot.
Topics128,069
Posts1,055,896
Members48,428
I have what I beleive to be a 1928 GMC 1 ton truck with a split flathead 6 cylinder engine made by Pontiac.
The distributor, Delco 639A, is toast, I think. we were cranking it over, and the distributor body started to turn. So much so that it tore off the cap and yanked the smaller wire that comes from the coil right off! eek eek
Anyway, I'm trying to remove it, but it only comes up so far, about 1/2 inch or so. I'm afraid to pry too hard on it for fear of breaking anything else. I've checked inside the valve cover, but I can't see anything there that would be keeping it from coming out.
Is there anyone out there who might have a clue as to what's keeping it in place? Does anyone have a source for rebuilt Delco distributors?
Steve
Is there a clamp bolt or setscrew that's supposed to anchor it to the block? I've got a Snap-On accessory for a slide hammer that was intended to remove a stuck distributor, especially on the mid-50's Ford V-8's. It's just a fork-shaped piece that screws onto the end of a slide hammer shaft. Maybe an oldtime shop around your area might have one. Stuck dizzys were pretty common on those engines.
Jed Offline
Steve, VCCA's (Vintage Chevy Club of America) site might also be of some help.
Yes, there was a clamp to hold it to the block, but I had already loosened it. It still doesn't want to come out.
I'll try the other sites forums as well. Thanks Guys!!
Steve
