2 members (Southerntruck, Bill Hanlon), 52 guests, and 4 robots.
Topics128,080
Posts1,055,952
Members48,430
#1425383 09/28/2021 5:06 PM
I'm nearly ready to paint my 1953 interior. I have replaced the inner cowl panels, so I now need to install a foot or two of the channel that the windlace slides into. I assume that I should drill a few holes in the center of the track and then weld it to the inner cowl panel. I'm a little concerned about grinding those welds flat enough to allow the new rubber to slide freely. I'll appreciate any advice regarding this. I also wondered if there is an adhesive that would work well enough that it wouldn't even need to be welded. I also wondered about possibly tack welding the new channel on the front edge, where it wouldn't show anyway. HELP
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Mike - like you described, I drilled 1/8" holes in the center of the track about 3" apart and plug welded it to the inner cowl panel. I then ground the weld so as to not interfere with the rubber installation. It worked out well for me. Just make sure to use a low heat setting on your welder so you don't blow through the track. They are not very thick. Good luck!!
Charlie
'51 3100 5-Window (Restomod in progress)
I did the same as Charlie when I replaced the lower portion of the tracks.
A small hole and a short blip with the MIG does the trick. You're doing it in the blind but sticking the cup centered on the track and pulling the trigger worked OK. I used a 3" cutoff disc to clean up the welds.
Moderated by  ndkid275, Phak1
