0 members (), 119 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
I recently had an LS swap done on my 52 Chevy 3100. While the shop had it I had them upgrade the steering to power steering with the newer outside the frame steering box. I have also installed new tie rod ends, new tie rod and installed new king pins and bushings. So all of the steering is brand new. When I drive and make a right turn or the wheel hits a dip just right it feels like the wheel is going to fold under the truck. Also, while driving on a winding country road it takes a lot of steering to get around the curve. I have yet to have the front end aligned as much as can be done with the straight axle but thought I would get some thoughts from here. I thought the steering would be nice and tight but it feels loose.
Thanks in advance.
Rcimp
52 Chevy 3100 5 Window, LS Swap, 4spd Auto, Vintage Air AC / Heat, CPP Power Front Disc Brake Conversion with bearing upgrade, Power Steering Conversion, LED Tail Lights
Crusing in the Passing Lane
What is the ‘newer outside the frame steering box?’ Have someone sit in the seat with the engine off and cycle the steering wheel while looking at each joint in the steering and axle attach point, remember when under the vehicle- always have the in your pocket.That would be a place to start.
Ed
You sure it's not over powered? Meaning to much pressure from the pump for steering box. What is the steering box gear ratio?
AD Addict & Tinkerer
You may consider bringing the truck back to the shop that installed the steering upgrade and get them to fix the issue they created.
drive
Phil
Project Journals
Stovebolt Gallery Forum
I reread you post about new kingpins so I edited my "check your kingpins" (Duh?! smile )
Are there any caster shims present?
I have the same style power steering in my '49 3100 and needed to increase the caster shims to 5 degrees to get the truck to handle properly.
When you come out of a turn, it is the caster which brings the wheels back toward straight ahead when you let go of the steering wheel. If yours does not do that, you need more caster. 5-7 degrees is what many end up with to fix this problem.
Replacing the heavy inline 6 with a lighter V-8 may well be the cause for the need to increase the caster angle to restore proper handling.
Most folks who have LS swapped a 47-54 truck have also done some sort of IFS thing.
However, there’s a member here who goes by “Barnfind49” who LS’d his truck with a largely stock front end. I think he might have even kept the manual steering and just moved it over.
I can’t find his project thread at the moment. But look him up, he might have some wisdom for you.
1951 3100
Your upgrade to power steering outside the frame and using a later model Saginaw
steering gear should not wander like that UNLESS the shop did not provide the
appropriate amount of caster to the axle. If all the other geometry they did is correct,
then you need a good 5-6 degrees of caster.
Get the caster and toe-in done at a quality alignment shop.
Caster shims are cheap!
I had the same set up in my panel truck with 455 Buick and steered beautifully.
