2 members (J Lucas, Erniegp),
78
Mod | | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 33 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 33 | Trying to hook up turn signals . Just bench testing now. Using a flasher that I had, the lights come on, but won't flash. I thought maybe bad flasher unit, so purchased a new flasher. With the new flasher the bulbs hardly even light up. You have to look real close to see that there is actually some light there and still no flash. Put old flasher in, and the lights are bright, but no flash. Do you think the new flasher is bad? I have everything grounded that I can think of. The turn signal switch is an old push button KD 723. Thanks for any help..I am only using the light assembly for turn signals, nothing else. 6 volt...52 Pickup..Thanks... | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | When I was 6-volts, I needed a new flasher. I bought a couple of new ones but they flashed way too fast.
So, I went to the junkyard and found a 6-V flasher in an Army AD truck. It worked perfectly for a long time until I switched to 12-v.
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Mechanical flashers require quite a bit of load to flash. So you need two bulbs with rather heavy filaments. I would buy a NOS 6 volt Tung-Sol or Signal Stat flasher on eBay and it will probably work. | | | | | Joined: Aug 2007 Posts: 33 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 33 | Thanks for the inputs. I will try two bulbs and see what happens.. | | |
