5 members (Oswald, DadsFirstPickup, Hotrod Lincoln, J Lucas, 1955 1 Series), 66 guests, and 1 robot.
Topics128,047
Posts1,055,622
#1425066 09/24/2021 1:33 PM
Trying to hook up turn signals . Just bench testing now. Using a flasher that I had, the lights come on, but won't flash. I thought maybe bad flasher unit, so purchased a new flasher. With the new flasher the bulbs hardly even light up. You have to look real close to see that there is actually some light there and still no flash. Put old flasher in, and the lights are bright, but no flash. Do you think the new flasher is bad? I have everything grounded that I can think of. The turn signal switch is an old push button KD 723. Thanks for any help..I am only using the light assembly for turn signals, nothing else. 6 volt...52 Pickup..Thanks...
tommyleea #1425072 09/24/2021 3:03 PM
When I was 6-volts, I needed a new flasher. I bought a couple of new ones but they flashed way too fast.
So, I went to the junkyard and found a 6-V flasher in an Army AD truck. It worked perfectly for a long time until I switched to 12-v.
tommyleea #1425119 09/25/2021 5:23 AM
Mechanical flashers require quite a bit of load to flash. So you need two bulbs with rather heavy filaments. I would buy a NOS 6 volt Tung-Sol or Signal Stat flasher on eBay and it will probably work.
tommyleea #1425133 09/25/2021 2:46 PM
Thanks for the inputs. I will try two bulbs and see what happens..
