Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (Ridgeback, Steelonsteel, TooMany2count, qdub, klhansen, Lightholder's Dad, joetravjr), 581 guests, and 2 robots.
Topics126,780
Posts1,039,291
Members48,100
Most Online2,175
Jul 21st, 2025
#1424977 09/23/2021 1:08 PM
Crusty Old Sarge
Crusty Old Sarge
I went with my Brother-in-law yesterday to pick up his newest project. He bought a 57' 3100 that from a local Classic Car Sales, the truck has been worked over to say the least. While I don't consider myself to be a "Purest" there are some things that I just don't agree with. I wish he had let me go over the truck before he completed the deal, it seems I now have some work to do.
The roof has been chopped about 3'or so inches, it has an older Corvette rear suspension with an early Camaro subframe grafted on the front. The fit of the windshield is questionable, the door glass isn't much better. The front suspension is way out of camber and the springs are aided with turn locks. While it does have 4 wheel disc brakes it has no booster or proportioning valve, no residual pressure valves. The brake master cylinder is mounted high on the firewall leaving the pedal a ways above the floor. The brakes barely stop the truck. There is a nasty vibration at 50MPH that gets worse with speed. The steering darts all over the place and hitting a bump will knock your teeth loose. I has a SB (he was told a 350??) with a mild cam and a what believe to be a Power Glide trans as I only count one shift.
The paint is a pearl white and looks decent from 20ft, the body work isn't that great either. There doesn't seem to be a uniform theme with this truck, it has roll pans front ant rear, hidden tailgate latches, 39' ford taillights, aftermarket HID headlights. The bed has a wood floor that was LineX'ed , the inside of the cab was also treated to this. The Battery is under the passenger side floor, accessed through a plywood cover.
I suppose I'm making a big deal of this but it just makes me wonder about some of the work that gets done to these old trucks. I fully understand wanting to make a Custom truck of your own design and style, but shouldn't safety play a large part in the design. I'll get off my Soap Box now.
57, 3100
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Come Bleed or Blister, something has got to give!!! | Living life in the SLOW lane
AD Addict & Tinkerer
Amen!
Phil
Project Journals
Stovebolt Gallery Forum
Hey, it’s a start! chug
back yard wrench turner
Somebody spent a small fortune on louvers.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
Wow "3' ". That's a hell of a chop job.
Flip it to another unsuspecting buyer.
I'm surprised you even went above 50 MPH given your description.
You don't have a death wish, do you?
So this is your BIL's project? It sounds like you've inherited it. Good luck with "his" project.
But you know that anything can be fixed given enough time and money. wink
Sir Searchalot
Sir Searchalot
Flip it into the lake and collect the insurance.
Crusty Old Sarge
Crusty Old Sarge
Well he has a Big Block F@%* that he spent a lot of $$$ on so this can't be any worse... YEAH RIGHT !!!
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Former Workshop Owner
If it were mine, the louvered hood would have to go. At least it’s a Chevy. thumbs_up
~ J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 32 Fleetside
My Flicker Photos!
TUTS 59 #1425055 09/24/2021 11:14 AM
The tail lights are 41 Chevy not 39 Ford. Didn't say which way camber is off but looks like lots of room for shims. Disc brakes without a booster are like no brakes at all unless you're King Kong. Glass is very hard to get right on anything with a wrap around windshield. My approach would be BRAKES, steering, and suspension. Once these are brought into spec then a drive will reveal if it is worth any more time or money.
Evan
TUTS 59 #1425056 09/24/2021 11:32 AM
Crusty Old Sarge
Crusty Old Sarge
Evan, that is spot on the approach I was thinking. I have a new vacuum booster that I didn't use with my 59' so that will be donated. Both the driver side and passenger front tires have about an inch of negative camber, there are about 3/4 inch of shims on the upper control arms now. The front end will take some figuring out, a good friend of mine does the set ups on the local round track cars, he should be able to help. I will get the truck up on the lift this weekend and get a better look at the overall chassis.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
What's annoying or depressing about that one is that it is kind of pretending to be finished. Looking all cool and custom as it does (at a glance) I'm sure that it brought a substantial price.
On the bright side , nice job putting on the happy face in the 1st image. Very entertaining!
Age 68 is not too late to start hot rodding , right?
Moderator
Moderator
2 Offline
With the distance the fan is from the radiator, three miles and the engine will boil over!
And that is not Tuts with the smiley face.
Don
"The Flag Pole"
'46 2-Ton grain truck | '50 2-ton flatbed | '54 Pontiac Straight Eight | '54 Plymouth Belvidere | '70 American LaFrance pumper fire truck | '76 Triumph TR-6
Crusty Old Sarge
Crusty Old Sarge
I put a of 50 Miles on it bringing it home and it never got a have 160. The smiling face is my BIL David. He is just happy that he has me to work on it.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
You can probably find some adjustable front control arms easily. I had camber issues on a 39 chevy coupe with a nova front end that the adjustable arms "fixed".
I found a mostly complete chevy truck in a wrecking yard and pulled the proportioning valve ect off it, then bought new parts from the FLAPS to complete the project.. it all worked great.
If you have flat door glass, then the "Hot Rod Glass" company might be able to help you out at a decent price.
Good luck... and make him to the work as you supervise!!
Another quality post.
Real Trucks Rattle
Crusty Old Sarge
Crusty Old Sarge
Rusty, I thought about adjustable control arms, good call. He thinks he needs a "Beer Assistant" not sure how much real work would get done.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Lipstick on a Pig! I bet you can’t wait to dig into that project!
Phil
Project Journals
Crusty Old Sarge
Crusty Old Sarge
He's already talking about fuel injection, it doesn't even have brakes yet! I reined him in a little for now, he needs to figure out what front clip is actually under the truck so we can find parts. He is fine with just making it safe at the moment, brakes, steering and suspension are the priorities. I'm sure it will get completely out of hand before long.
Building my 59' has taught me many lessons, most the hard way. I should have never disassembled the truck, should have tackled one project at a time with and end goal in mind. My BIL (David) has never kept a project for very long, he goes from one to another leaving a lot undone. The Big Block F@&d is just the latest, it was just painted and doesn't have the drivetrain completed and he is already wanting to sell it. Time will tell.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1425322 09/27/2021 10:57 PM
We have to keep people like him around to sell partially completed projects to the restof us cheap.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
TUTS 59 #1425327 09/28/2021 12:11 AM
[quote=TUTS 59] He is fine with just making it safe at the moment, brakes, steering and suspension are the priorities.
That was exactly my intention !!!
Now look ---
Originally Posted by Fibonachu
We have to keep people like him around to sell partially completed projects to the rest of us cheap.
That's how I got most of my old vehicles! Some people rescue cats & dogs...I rescue old cars and trucks!
-Kevin
This is what happens when you live with a house-full of women, the wife and daughters name all the cars:
1960 Impala - "Frankie" (Frank Sinatra)
1961 Apache - " 'Mater Jr." (wrecker)
1965 Corvair Monza Convertible
1967 C20 "Ol' Blue" (hidden in a log cabin for 30 years)
1972 SuperBeetle Convertible - "Juliet"
1976 SuperBeetle Convertible - "Olaf"
1988 Alfa Romeo Spider Veloce - "Romeo"
TUTS 59 #1426237 10/08/2021 11:07 AM
Before investing in adjustable control arms take it to a GOOD front end shop and have the front cross member bent back to factory specs. Most have sagged during the years to a point shims can't correct. Once the upper A-frame mounts are back in position alignment problems disappear.
Evan
Crusty Old Sarge
Crusty Old Sarge
I'm not sure if we have a shop around here that would get that involved. Locally we only maybe one shop that still may have that kind skill, the guy is a little grumpy, think "Jerry" and add a very mean disposition. grin
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
7
7 Offline
You wish the guy who built the truck kept records of the parts he used. The front clip, the rear end so you know where to start. Brakes, suspension and frame. Hope all works out.
1946 1/2 ton
Crusty Old Sarge
Crusty Old Sarge
Well I got the truck on the lift today and had a good look at the frame and modifications. It's about like I thought some scarry stuff going on under a pearl paint job.
I'm going to start a thread in the projects forum to track the work being done.
Some pics just for a taste.
57 Chop Top frame
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Moderator
Moderator
2 Offline
WOW Craig, some major Cobalogee stuff going on under there.
And as for the welds, we’ll wait for Jerry to comment.
Don
"The Flag Pole"
Looks like you have some cutting ahead of you.
Wayne
TUTS 59 #1426889 10/15/2021 12:20 AM
You think those are booger welds?
I’LL show you booger welds!!!
I think we all have examples of those. Maybe not hanging on the shop wall for all to see, but.....
TUTS 59 #1426918 10/15/2021 11:30 AM
Right᠁
Better ground down , cut out , plated over and properly welded.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 3.614s Queries: 19 (3.609s) Memory: 0.7591 MB (Peak: 0.9684 MB) Data Comp: Zlib Server Time: 2025-09-22 19:30:05 UTC
Valid HTML 5 and Valid CSS
