Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (homer52), 118 guests, and 6 robots.
Topics128,281
Posts1,058,469
Members48,490
#1424894 09/22/2021 3:27 PM
can sometell me best/ easiest way to remove foot starter and put starter button on dash or just key start
What vehicle are you working with?
A 1958 truck (what model - what engine size/year)?
A 1958 truck engine (what model)- what engine size/year - into an earlier truck (what model/year)?
You could convert to a starter from a passenger car or a later (60-62) truck with a 235 engine. Some of the wiring would have to be changed to accommodate the change over. I personally prefer the foot starter on that era trucks.
Fred
my truck is 1958 chevy has a gmc 270 6cylinder with foot start, i would like to either use button start or key how do i convert?
back yard wrench turner
As stated above, 1st you need a starter with an electric solenoid. Wiring would need changed to accommodate using a push button or a key start.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
my engine is a GMC inline 6cylinder 270, can someone tell what would be the proper starter with elec solonoid would fit in to do this conversion?
Most would presume that a question regarding a 58 Chevy truck with a floor starter would have a 235 or 261 Chevy engine unless it's stated in the question. It's possible that the same starter is used in the GMC 6 cylinder engines. I don't know, possibly someone else has some insight on this.
Fred
Not sure but a starter that is used with the Hydramatic may fit and do what you want. I suggest using the key switch and avoiding drilling holes.
It looks like the starter numbers are different for different engines and different transmissions (manual vs Hydra-Matic).
1958 truck 6 cylinder engine
1958 truck 8 cylinder engine
A 1955-62 passenger car six cylinder starter, or a 1960-62 six cylinder truck starter should do the trick.
My Blog
Dave,
Would 6-cylinder manual transmission and automatic transmission starters be the same?
The 6-cylinder link that I posted above seem to indicate that they are different?
From the parts book, it looks like powerglide starters are the same as manual.
I believe the solenoid position is special on the Hydramatic starter, and there may be other differences. It is also a very rare one.
My Blog
