1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2020 Posts: 112 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 112 | ive tried to find some sort of kit but it seems us 1bbl guys are left out of the mix. i am searching for someone who makes a plate style wet kit for our 6cyls, cost efficiency is the name of the game here and i have an entire nitrous setup, but i am missing a plate for it to screw into, and i cannot find a 1bbl plate, anyone know of one? thanks!
THE BLACK VIKING 1958 Viking 60 ~ my new toy hauler My Current fleet: 1954 chevy 3800, 1953/4 gmc 450 coleman 4x4, 1956 chevy pickup, 1958 Viking 60 Keep 'em rollin fellas!
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | How are those spaghetti-thin connecting rods going to react to a dose of "go fast" ????? You're going to need about $2K worth of H-beam connecting rods and forged pistons. The crankshaft should be strong enough to handle the load, but the pistons and rods don't have a chance. I'm using a set of 6 1/2" long H beam rods in a stroker engine I'm building on a 261 block. Jerry
| | | | | Joined: Sep 2019 Posts: 159 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 159 | Could you not find a machine shop that can fabricate one out of a block of aluminum, given detailed information? Also what six are you planning to do this with? A 216? Haha, just kidding! Good luck and let us know how it goes.
I invest my money in precious metals, mostly rust!
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Using a plate mounted nitrous set up on an early style stovebolt probably runs into the same issues as trying to use throttle body efi on an early stovebolt, The Siamese intake ports. Very likely to have the additional fuel injected to support the additional o2 released during nitrous burn puddle in the intake and cause a lean out, and then a melt the piston event, in addition to the rod issue identified by HRL.
Mike
| | | | | Joined: Jul 2020 Posts: 112 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 112 | I was looking for a small 35 shot just enough to give her a little boost when she needs it until my smallblock was done and like i said i had a whole kit just minus a plate and a full bottle laying around. So i figured why not. Ill have to look into having a plate made.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might get more readers in the HiPo Shop?The HiPo Shop (9 viewing) Thinking about a hotrod, street rod or other custom work? Stop in here. Shoot, we'll even talk about power brakes, power steering and CD players! Moderated by: KCMongo | | |
