4 members (DoubleB, greenie-reddy, 41appletruck, Oswald), 85 guests, and 1 robot.
Topics128,091
Posts1,056,038
Members48,433
#1424533 09/19/2021 2:10 AM
Anybody use one of the abs hood insulation kits from places like LMC and etc? Looking to get good and/or bad thoughts on them. A picture installed would be nice as well. Thank you in advance for your thoughts.
Adam
Adam
Insomniac
Insomniac
I used Dynamat 11905 peel and stick insulation under my hood. Mainly for cosmetic reasons.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Adamg Once got a gift truck that the hood was real heavy on,discovered they had undercoated it real heavy. Scraped that all off and had a dandy like new hood under there.
Did the A D trucks come from the factory with insulated hoods?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Hoods were not insulated. At least mine wasn't.
My 1948 3106 panel truck, and three 3104 1954 pickup trucks did not have hood insulation.
My 54/55 GMC 2-ton COE did not have hood insulation.
All were unmutilated (un "enhanced) - all with original equipment (no "upgrades/enhancements").
Thanks for the thoughts so far guys. I wasn’t trying to say that the insulation was stock to the trucks. Just wanted to see if anyone had used them and their thoughts on them. It was also possibly going to be a way for me to cover up a past”primitive” repair to the underside of the hood. I think I may have been able to work the area enough that it blends fairly well now. I was just curious on the insulation. Thanks
Adam
Adam
The only "insulation" that was on the hoods was between the rear hood brace and the hood sheet metal. It acted as an anti vibration/noise insulator. It wasn't very big.
mjke burns That undercoated hood was done at a local chevy dealer by brothers,they were kind of eccentric.
I’m not home to take a picture, but in the attached photo you can see the corner of a self stick foil faced Eastwood XMat I used. I didn’t do any prep work so unfortunately most of it didn’t stick for long. Luckily, the hood crossbraces have kept it off the engine. I do think it reduced noice inside cab while it stuck. Not sure why though.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
