7 members (Steve L., WICruiser, Bill Hanlon, Bucker, Peggy M, Hotrod Lincoln, klhansen),
68
Mod | | | Forums66 Topics128,206 Posts1,057,435 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 22 Junior Member | | Junior Member Joined: Nov 2004 Posts: 22 | Does anyone know what the rated GVW was of a '53 GMC W450-30 (Tandem rear axles)?
Thanks | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I've got a spec. sheet, on a DW450-37, & it's 26000lb. GVW, & 38000lb. GCW. | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | The GVW should be stamped on the doorjamb plate... 44,000 is normal with 9.00x20 tires..tire size will dictate what you can license for..
Geoff
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Is this the one that was for sale in Spokane? I think I concluded that one was 26,000 or maybe 29,000. It was the number that Washington says requires a CDL unless it has juice brakes and is not operated commercially.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2004 Posts: 22 Junior Member | | Junior Member Joined: Nov 2004 Posts: 22 | Yup. Turns out it's GVW is 26,000 and GCW = 38,000, right off the ID plate. Washington requires a CDL for single trucks 26,001 and above, or trailers 10,001 and above if the GCW is 26,001 or above. So this truck would not need a CDL. I suppose the GMC 470 series would need one. It's a W454-30, so the wheelbase is 179". I will be calling the guy tomorrow for more details on condition, etc. | | |
