7 members (TUTS 59, niobrarafun, Nick in Manitou, lumbersawyer, SmalltownTRKGuy, 55shaker, Oldpickupman), 106 guests, and 2 robots.
Topics128,195
Posts1,057,378
Members48,469
#142423 04/16/2005 2:03 AM
Junior Member
Junior Member
Does anyone know what the rated GVW was of a '53 GMC W450-30 (Tandem rear axles)?
#142424 04/16/2005 2:32 AM
I've got a spec. sheet, on a DW450-37, & it's 26000lb. GVW, & 38000lb. GCW.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#142425 04/16/2005 2:36 AM
The GVW should be stamped on the doorjamb plate...
44,000 is normal with 9.00x20 tires..tire size will dictate what you can license for..
Geoff
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
#142426 04/16/2005 3:46 AM
Is this the one that was for sale in Spokane? I think I concluded that one was 26,000 or maybe 29,000. It was the number that Washington says requires a CDL unless it has juice brakes and is not operated commercially.
#142427 04/25/2005 2:25 AM
Junior Member
Junior Member
Yup. Turns out it's GVW is 26,000 and GCW = 38,000, right off the ID plate. Washington requires a CDL for single trucks 26,001 and above, or trailers 10,001 and above if the GCW is 26,001 or above. So this truck would not need a CDL. I suppose the GMC 470 series would need one. It's a W454-30, so the wheelbase is 179". I will be calling the guy tomorrow for more details on condition, etc.
