| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2021 Posts: 25 'Bolter | | 'Bolter Joined: Apr 2021 Posts: 25 | Any recommendations for a great paint on rust converter?
Winerytruck | | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 | Eastwood has a few nice products. I just used their Eastwood Rubberized Rust Encapsulator on my battery tray after sanding it a bit. https://www.eastwood.com/rust-encapsulator-rust-converter-paint-car-auto-rust-protection
1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | I like Master Series Silver. https://masterseriesct.com/ Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Nov 2005 Posts: 324 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 324 | I'm using Ospho on my project. It is easy to use, has a consistency like water. Just brush on and wait a day, then I spray on some primer. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Before deciding on a “rust converter” product you should check to insure your primer is compatible with said converter. Many epoxy primers do not play nicely with these acid type treatments. Having to repaint something, and giving the cost of paint supplies, it is imperative to get it right the first time. My suggestion is to start with your epoxy primer and check with THAT manufacturer to see if their product is compatible with these rust converters. | | | | | Joined: Apr 2021 Posts: 25 'Bolter | | 'Bolter Joined: Apr 2021 Posts: 25 | Walter: What brands of epoxy primer have you used successfully with the Ospho rust converter. ?
Thanks to all of you for your replies.
Winerytruck
| | | | | Joined: Nov 2005 Posts: 324 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 324 | I decided to not use epoxy primer, I'm using Rustoleum rusty metal primer on the interior. I have encountered a couple spots that bubbled or cracked, may have been due contamination. Overall I'm happy with the results. I still need to figure out what plays nice with the product I will use on the exterior. Robert gave the best advice here to check product compatibility. | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | I've used Rustoleum rusty metal primer on some small parts, topcoated per instructions with their semi-gloss black. I've found lately that combination isn't very durable and scratches easily. I painted the road draft tube with it and it has already been chipped from being in the box waiting to be installed. It can be touched up, but I've found that epoxy primer with the same topcoat is a lot tougher and scratch resistant. Just an observation.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
