2 members (Gdads51, Guitplayer), 76 guests, and 3 robots.
Topics128,162
Posts1,056,950
Members48,458
Can anyone identify this rim? I got rid of my widowmakers and was offered these, but I don't know if they would be better.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
oldieoldie My 51 6400 came with those on the front 90% rubber working fine after 8000 local miles.
In my opinion the 3 piece was the safest multi piece wheel you could get in those days. These look pretty rusty. Be sure to inspect them inside. Otherwise, by design, they were the most desirable for tube type tires.
Is this a 3 piece rim then? It would be ok if not too rusty? I really don’t know what I’m looking at to know if they are safe. I would plan to blast and paint whatever I get.
Crusing in the Passing Lane
Those are 10 on 7.25” bolt pattern, rarely found as tubeless rims starting in late ‘50’s. If found can use modern 9 x 22.5” tires.
Ed
Won’t they be for 20 inch tires? I’d love 22.5 rims but haven’t found any.
Yes you are correct, ALL 20" rims are multi-piece tube type rims...ALL 22.5" rims are one piece tubeless.
The only multi-piece rim that's been "outlawed" is the Firestone RH-5...all other multi-piece rims are still serviceable as long as they are not damaged or rusty.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
The wheel in your photo uses a full circle bead ring retained by a small diameter split ring that's wedged into a groove in both pieces as the tire inflates. As long as the grooves and the lock ring aren't severely rust damaged, they're perfectly safe once full inflalation pressure is reached. Once the old tires are removed, work the lock ring area on all the pieces over with a wire cup wheel on an angle grinder down to bare metal, and do a detailed inspection.
NEVER, EVER TRY TO ADD AIR TO A TIRE ON A MULTI-PIECE RIM THAT'S NOTICEABLY LOW- - - -flat, or with a bulged sidewall, for instance. The lock ring relationship could be compromised, resulting in a deadly rim separation.
oldieoldie Now this is just my opinion but when you blast any metal that is very rusty you really lose a lot of it's integrity. My 51 3600 homemade dually rear wheels were solid so I just used the needle scaler ( like a welder uses) painted with por 15 2 coats. Then put on new rubber,that's been 15 years ago hauled a lot of wood since. Still just fine !
oldieoldie One other thing use a clip-on air chuck and long hose to inflate ,don't trust 70 year old antique wheels.
