3 members (KEVINSKI, 68ironhead, 1 invisible),
103
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | A few clips on a couple of the stock 16 inch wheels seem to be a bit weak or damaged. None of the clips are missing. The hubcaps mount securely enough to stay on, but can be removed with minimal effort using a tool. It seems likely a cap will eventually be lost. Wondering if clips can be adjusted and if so how; or should they be replaced? | | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | They seem to be spring steel. Care must be taken when attempting to bend them. The 55.2 through 59 only came with 3 clips, so if your caps seem to be secure enough, I would leave the clips alone. You already have twice as many clips than the later models.
| | | | | Joined: Oct 2019 Posts: 131 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 131 | I lost a hub cap on my’37 due to weak clips. New ones are available from The Filling Station. Use an air chisel to hammer the new rivets | | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | Thanks to all for the info! | | |
