Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (55shaker, 78buckshot, TrknGMC, Joe H, Gdads51, 1 invisible), 94 guests, and 4 robots.
Topics128,274
Posts1,058,436
Members48,490
#1423145 09/06/2021 6:42 PM
A few clips on a couple of the stock 16 inch wheels seem to be a bit weak or damaged. None of the clips are missing. The hubcaps mount securely enough to stay on, but can be removed with minimal effort using a tool. It seems likely a cap will eventually be lost. Wondering if clips can be adjusted and if so how; or should they be replaced?
They seem to be spring steel. Care must be taken when attempting to bend them.
The 55.2 through 59 only came with 3 clips, so if your caps seem to be secure enough, I would leave the clips alone. You already have twice as many clips than the later models.
' Offline
I lost a hub cap on my’37 due to weak clips. New ones are available from
The Filling Station. Use an air chisel to hammer the new rivets
Thanks to all for the info!
