Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (JW51, 68ironhead, baldeagle, GMCJammer51, Bill Hanlon), 28 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
#1423125 09/06/2021 4:25 PM
Any recommendations for a great paint on rust converter?
Winerytruck
Eastwood has a few nice products. I just used their Eastwood Rubberized Rust Encapsulator on my battery tray after sanding it a bit.
https://www.eastwood.com/rust-encapsulator-rust-converter-paint-car-auto-rust-protection
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
back yard wrench turner
I like Master Series Silver. https://masterseriesct.com/
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I'm using Ospho on my project. It is easy to use, has a consistency like water. Just brush on and wait a day, then I spray on some primer.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Before deciding on a “rust converter” product you should check to insure your primer is compatible with said converter. Many epoxy primers do not play nicely with these acid type treatments. Having to repaint something, and giving the cost of paint supplies, it is imperative to get it right the first time. My suggestion is to start with your epoxy primer and check with THAT manufacturer to see if their product is compatible with these rust converters.
Walter:
What brands of epoxy primer have you used successfully with the Ospho rust converter.
Thanks to all of you for your replies.
Winerytruck
I decided to not use epoxy primer, I'm using Rustoleum rusty metal primer on the interior. I have encountered a couple spots that bubbled or cracked, may have been due contamination. Overall I'm happy with the results. I still need to figure out what plays nice with the product I will use on the exterior. Robert gave the best advice here to check product compatibility.
In Project Journals
In the DITY Gallery
I've used Rustoleum rusty metal primer on some small parts, topcoated per instructions with their semi-gloss black. I've found lately that combination isn't very durable and scratches easily. I painted the road draft tube with it and it has already been chipped from being in the box waiting to be installed. It can be touched up, but I've found that epoxy primer with the same topcoat is a lot tougher and scratch resistant. Just an observation.
