3 members (JW51, mo2cyl, 1 invisible), 223 guests, and 1 robot.
Topics128,083
Posts1,055,967
Members48,430
#1419424 08/04/2021 5:51 PM
Actually, I’m trying to repair my fresh air heater cable. It is frozen and I can’t pull the cable. If I buy a generic cable, how do I remove the knob from the old cable and attach it to the new cable?
one of the vendors sells the cable and knob for $55 and a choke cable with knob for $14.
Ex Hall Monitor
Ex Hall Monitor
Before I started jumping through those hoops I'd pull the old cable and soak it in PB Blaster. Just coil it up and lay it in a pan of penetrant. Let it soak a day. If that's not long enough soak it two days. I'd warm the penetrant too. If you can save the OEM cable you'll be ahead of the game.
Riding in the Passing Lane
If the knob is molded on the shaft, heat the shaft as you pull on the knob. When the plastic gets hot enough the knob will pull off. Use super glue to put it on the new cable.
George
1972 Chevy c10 Cheyenne Super
Another thing that sometimes helps is to take the cable and use it like a whip and hit the garage floor with it a few times. Helps to break the rust loose and get it moving again.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
modial Take the right knob and saw off the wire far enough up you can drill in the center of that 3 inch stem. Crazy glue your wire in it,may have trouble keeping your letter upright on C or T. Drill in there 1/2 inch if possible no oil. Hope that helps.
This was good information. I need to free up my existing Throttle cable. I plan to repurpose it as a control cable for a heater valve to shut off the water to my heater in the summer.
Dave from Northern Kentucky
My 54 3100
The cable was sprayed with pb blaster and allowed to sit (I forgot about it). I went outside and tried my best Indiana Jones whip slaping the cable on the ground. Inwas able to slide the center wire all the way out. I cleaned it with steel wool, and straightened out all the kinks I could. The wire now slides in and out of the cable with little resistance. Thanks to everyone and their suggestions.
Ex Hall Monitor
Ex Hall Monitor
I'm glad it worked for you.
