1 members (Hotrod Lincoln ),
72
0
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,049
Posts1,055,680
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
2 carbs from my stash. I would like some help to identify and what they might be suitable for. 1. first 2 pictures. Fuel intake without filter. Tag: 7015011, / D2. underside of bowl: 7004497-c-4 (stamped) 2. last 2 pictures. Automatic choke, Tag: 7025105, 45 / 42. underside of bowl: 7025382 (in circle pattern)
Insomniac
Insomniac
7015011 is for a 1960 truck with 235 engine. Standard (all trans) The other one is for a smaller 6. Info attached....
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed
Ok. What is BOP? I see what the carb might be used for but BOP...? Thanks for the info.
Here’s info I gathered when I investigated the tag on my carb. Carb King supplied the details. On 10/10/11 I carefully removed the tag from the carburetor. Can you see the "R" and a "P" just beneath it at the top of the triangular tag? The "RP" stands for Rochester Products. Kudos to Stovebolt.com forum member "Carbking" who correctly decoded the tag. 70 = prefix used for all mid-to-late 60's Rochester carburetors 2 = 1960's 3 = 1963 (the 1st year carb was introduced) 0 = 1 barrel carb 1 = Chevrolet 7 = manual transmission C = 3rd production engineering change F5 = June 1965 90 = badge # of the final inspector
Riding in the Passing Lane
BOP is Buick Olds Pontiac. George
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne Super In the Gallery Forum
thanks all. BOP - I never would have gotten there. Thanks George.
The first appears to be for the 216. If it’s the ‘49-‘50 Rochester it can be prone to being a bit problematic as far as being road worthy. I know this from personal experience.
I invest my money in precious metals, mostly rust!
Here is a 3rd carb for identification. Id numbers are rolled on.
That is a later model rochester mono jet carb. ( New and Improved model b.)
Tommy 59 apache 1/2t 261 short stepside
