3 members (KCMongo, HelmutVonSchet, 59 fleet), 90 guests, and 0 robots.
Topics128,049
Posts1,055,679
#1421778 08/24/2021 10:37 PM
2 carbs from my stash. I would like some help to identify and what they might be suitable for.
1. first 2 pictures. Fuel intake without filter. Tag: 7015011, / D2. underside of bowl: 7004497-c-4 (stamped)
2. last 2 pictures. Automatic choke, Tag: 7025105, 45 / 42. underside of bowl: 7025382 (in circle pattern)
~ HB
1962 Chevrolet C10
1962 Suburban
Insomniac
Insomniac
7015011 is for a 1960 truck with 235 engine. Standard (all trans)
The other one is for a smaller 6.
Info attached....
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Ok. What is BOP? I see what the carb might be used for but BOP...?
Thanks for the info.
~ HB
1962 Chevrolet C10
1962 Suburban
Here’s info I gathered when I investigated the tag on my carb.
Carb King supplied the details.
On 10/10/11 I carefully removed the tag from the carburetor. Can you see the "R" and a "P" just beneath it at the top of the triangular tag? The "RP" stands for Rochester Products.
Kudos to Stovebolt.com forum member "Carbking" who correctly decoded the tag.
70 = prefix used for all
mid-to-late 60's Rochester carburetors
2 = 1960's
3 = 1963 (the 1st year carb was introduced)
0 = 1 barrel carb
1 = Chevrolet
7 = manual transmission
C = 3rd production engineering change
F5 = June 1965
90 = badge # of the final inspector
Riding in the Passing Lane
BOP is Buick Olds Pontiac.
George
1972 Chevy c10 Cheyenne Super
thanks all. BOP - I never would have gotten there. Thanks George.
~ HB
1962 Chevrolet C10
1962 Suburban
The first appears to be for the 216. If it’s the ‘49-‘50 Rochester it can be prone to being a bit problematic as far as being road worthy. I know this from personal experience.
I invest my money in precious metals, mostly rust!
Here is a 3rd carb for identification. Id numbers are rolled on.
~ HB
1962 Chevrolet C10
1962 Suburban
That is a later model rochester mono jet carb. ( New and Improved model b.)
Tommy
59 apache 1/2t
261 short stepside
