0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2018 Posts: 128 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 128 | I am trying to install new window channels in my 1949 Chevy truck. I currently have the glass and crank out of the door. Old channel is out. I have tried window channels from two different vendors and have ruined both trying to install them. The problem I have is the window channels want to kink when I try to put them in the doors. I've ordered another set, but really don't want to destroy another set. They are getting expensive. Any advice or tips would be appreciated. I've watched the Youtube videos from USA1 Industries and they make it look like a piece of cake. Unfortunately, I have not had the same results. | | | | | Joined: May 2015 Posts: 11,024 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,024 | The window channel is corrugated metal inside, so should form around corners without kinking. I haven't attempted installing mine yet, but maybe devise a tool like a paddle with the same thickness as the glass to push the channel into the corners. The paddle may prevent the sides from collapsing into the space where the glass goes.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 | I think I used a heavy paint stick like the ones they give you at big box stores with a 5 gallon bucket of paint. 1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: May 2015 Posts: 11,024 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,024 | I think I used a heavy paint stick like the ones they give you at big box stores with a 5 gallon bucket of paint. Good idea. I have about 20 of those.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | When I installed my window channels I "fit them to the window" first. I clamped a door window into a vice using paint sticks between the widow surface and vice jaws. I measured the distance of the window channel straight section from the retainer in the bottom of the door door up to the "radius " in the door window opening ( tangent point where the straight part ends and the radius begins ) . I then marked the channel section using that length to establish where the bend would start. I marked the window with a Paint line at that same radius and then placed the channel against the window lining up the two marks and then carefully formed the window channel over the window. This allowed me to make that radius bend very accurately.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I first straighten the channel. I don't know why the manufacturers bend them in the opposite direction. Maybe they naturally bend in that direction without kinking. I then insert one end into the rear of the door until it engages with the doohickey at the bottom of the door channel. The extra length will go straight up in the air outside of the window opening. I then carefully make the first bend to fit the radius of rear of the door. The long end of the channel will extend past the front of the cab. I then carefully make the second bend to fit the radius of the front of the door. This can be done without inserting the channel inside of the door. it can hang outside of the window opening. I then remove the channel from the door, then install it by inserting both ends into the door channels. Don't worry about engaging the front end into the doohickey at the bottom of the front door channel. Allow it to go past the end of the door channel at this time, as it will need to be cut to length later. Now roll the window up to aid in forming the channel to fit the glass. The cornes will have some kinks which can be worked into place with wide screw driver. Once the channel fits the glass with the window all the way up you can mark the front end of the channel to cut to the proper length and insert it into the doohickey at the bottom of the door channel.
| | | | | Joined: Feb 2018 Posts: 128 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 128 | Carl, that is interesting. All the videos I watched showed putting the window felt channel in before putting the window and rolling mechanism in the door. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | The Manual instructions describes replacing it with the glass installed.
| | | | | Joined: Dec 2021 Posts: 105 'Bolter | | 'Bolter Joined: Dec 2021 Posts: 105 | I know this thread is old - but where did you guys get your channel. I ruined two that were bent the WRONG way from the supplier. Straightening first, then bending correctly didn't work, even using my glass as a form. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | They are all bent wrong by the vendors. You just need to go slow and massage them as you go. The metal is crimped up like an accordion, making it possible to get it to work.
| | | | | Joined: Dec 2021 Posts: 105 'Bolter | | 'Bolter Joined: Dec 2021 Posts: 105 | What do you mean massage 52Carl? I used an old window glass for a form. I used the paint stir stick technique, I had a channel lock pliers standing by and all ten fingers pressing against a flat table. No success. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I start out by making them straight. I them shove one end into the door until it engages with the little retainer clip at the bottom, leaving the excess sticking straight up on the outside of the window opening. I them begin the first bend at the upper rear corner of the window opening. Slow as you go, mashing the buckling as they appear with lineman pliers and wide blade screw driver. Once that corner is done, I move on to next bend (or to mark it to be cut to length at the vent window). You may not be using the right quantity of beer prior to this operation. That can be detrimental.
| | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | I just finished installing mine and Carl’s advice is right on, make it straight first then work in the bend. I used my vice to keep the channel from spreading out as I straightened and bent the channel. As you work, straighten out any kinks before they get too big. I used a lineman's pliers, vice and a piece of 1/4” plywood to help form the channel. I also cut one end of the plywood to the contour of the corner of the window to help drive it further into the corner.
It took me several hours to get them installed. Bend the corner a little bit at a time so it doesn’t kink and you’ll get it done.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
