2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1421275 08/20/2021 5:58 PM
Can a 235 Crank #3701486 be used in a 1962 235?
Bumpa49 #1421276 08/20/2021 6:12 PM
some info from the past from Paul, Jerry, Dave and Jim
Bumpa49 #1421278 08/20/2021 6:17 PM
I read this thread but It only mentions that the bearings are the same up to1961. What about 1962?
Bumpa49 #1421280 08/20/2021 6:30 PM
H Online: Content
All the 235/261 pressure-lubed crankshafts are identical, so far as I know. The 1941-53 235 spray-oiler cranks have the same rod and main bearing diameters, but the #3 main bearing thrust faces are wider. A pressure-oiled 235 crank will fit a 216 block by machining the thrust faces for the wider bearing, but the 216 pistons would stick out of the top of the block 1/8" unless a shorter connecting rod or a custom piston is used.
Bumpa49 #1421289 08/20/2021 7:48 PM
Thanks for the information. I happened to find in my Motors Manual that the 1962 crankshaft has main bearing journals that are .002" larger than the journals on the 54 to 61 types. Everything else is the same. I am trying to find if the 1962 crank had a different casting number.
Bumpa49 #1421291 08/20/2021 8:18 PM
H Online: Content
Your "Motors Manual" is wrong. The federal-Mogul engine bearing specification manual #115, dated 1982 which supercedes the 1980 edition lists the same crankshafts from 1956-63 for the 235 AND 261 engines. They have the following forging numbers:
3701486
3701488
3701488A
3770327
All the above crankshafts use the same rod bearings, Federal-Mogul 1950CP, and main bearings, F-M # 960M. THERE ARE NO DIFFERENCES IN MAIN BEARING DIAMETER FOR ALL THESE CRANKSHAFTS.
Bumpa49 #1421296 08/20/2021 8:46 PM
Thanks, both the Chiltons and Motors Manual list a .002" difference in diameter. I will go with your information.
