9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible),
43
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2019 Posts: 10 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 10 | Can a 235 Crank #3701486 be used in a 1962 235? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | some info from the past from Paul, Jerry, Dave and Jim | | | | | Joined: Apr 2019 Posts: 10 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 10 | I read this thread but It only mentions that the bearings are the same up to1961. What about 1962? | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | All the 235/261 pressure-lubed crankshafts are identical, so far as I know. The 1941-53 235 spray-oiler cranks have the same rod and main bearing diameters, but the #3 main bearing thrust faces are wider. A pressure-oiled 235 crank will fit a 216 block by machining the thrust faces for the wider bearing, but the 216 pistons would stick out of the top of the block 1/8" unless a shorter connecting rod or a custom piston is used. Jerry
| | | | | Joined: Apr 2019 Posts: 10 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 10 | Thanks for the information. I happened to find in my Motors Manual that the 1962 crankshaft has main bearing journals that are .002" larger than the journals on the 54 to 61 types. Everything else is the same. I am trying to find if the 1962 crank had a different casting number. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Your "Motors Manual" is wrong. The federal-Mogul engine bearing specification manual #115, dated 1982 which supercedes the 1980 edition lists the same crankshafts from 1956-63 for the 235 AND 261 engines. They have the following forging numbers: 3701486 3701488 3701488A 3770327
All the above crankshafts use the same rod bearings, Federal-Mogul 1950CP, and main bearings, F-M # 960M. THERE ARE NO DIFFERENCES IN MAIN BEARING DIAMETER FOR ALL THESE CRANKSHAFTS. Jerry
| | | | | Joined: Apr 2019 Posts: 10 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 10 | Thanks, both the Chiltons and Motors Manual list a .002" difference in diameter. I will go with your information. | | |
